Ricoh 220/270 scanrouter
  • chris
    • Jul 2008
    • 10
    Does anyone have the original scanrouter software for the 220/270? It looks like the scanrouter v2 lite is not compatible with the 270 is that correct? If anyone has it and can email it or dropload to wndotinter@yahoo.com i would certainly appreciate it.
    Thanks, Chris.
  • netsrvs
    • Aug 2008
    • 26
    I think V2 is compatible but setting the I/O device on these older models is much different. To my knowledge you have to set the delivery server IP (scanrouter server) at the machine.
    From my notes.....
    1.Choose user tools/counter from the left side of the display screen
    2.Press #5 on the number key pad to select scanner options
    3.Press the button under config to select config mode
    4.Check function priority, should be delivery.
    5.Continue to scroll down until you see delivery option
    6.Their will be a * next to the selected option
    7.Select delivery and press the # key. It should put a * next to the selected option
    8.You will need to reboot the machine using the red power switch on the front side of the machine under a clear plastic cover for the setting to take effect.
