Windows 11 Update 22H2
    • 8137
    Access Control Panel options from the Settings app
    In a recent update for Windows 11, we started moving some settings from Control Panel to the Settings app.
    • The following settings have been moved from Control Panel to the Settings app:
      • Programs & Features
      • Devices & Printers
      • Default programs
      • VPN and Advanced sharing settings
    • Note: If you try to access these settings in Control Panel, you might be redirected to the Settings app.
    • Where can I find my Devices & Printers settings?
    • You can now manage your devices and printers in the Settings app. Here's what you can do:
      • To access extended device information and third-party extensions, select Start > Settings > Bluetooth & devices > Devices > More devices and printer settings.
      • To access detailed printer information, select Start > Settings > Bluetooth & devices > Printers & scanners > Printer model > Device information.
      • For more printer device info and third-party printer extensions, select Start > Settings > Bluetooth & devices > Printers & scanners > Printer model > More devices and printer settings.
    • Note: Device and printer hardware properties can also be accessed from Device Manager.
    ... this bomb kind of dropped out of the sky from Microsoft so expect a rocky few weeks from your customers and a quick re-learning about how you install and manage print drivers.
    Not so bad with IP printers but troublesome for USB printers.
  • tsbservice
    Field tech
    • 7963
    Re: Windows 11 Update 22H2
    I'm average Windows user but does M$ dropped Search function? I use it all the time instead of having to learn all the changes they made to new versions. It may sound silly but I don't give a sh!t where exactly Devices and Printers are as long typing word print in Search field works.
    • techsxge
      • Jan 2022
      • 660
        • Default programs
      I'll have to look into this but shouldnt that mean that i can more easily set the printers via powershell now? In general, Things found under settings are easier to access and use than things in cp.
      If this is the case i can probably throw away 2k lines of code and finally release the tool bc it will work proper
        • 8137
        ... perhaps, I and probably 99% of the service techs out there do not have a clue what you are talking about.
        I have been trying to familiarize myself with the new format that Microsoft forced upon everyone. You do not want to learn how to navigate the new structure in the field for the first time in front of a customer.
        There is one constant in this industry and that is learn or die.
        Most A3 copiers are connected as an IP printer and some A4 copiers especially those in lower price points are connected as USB printers.
        I have been able to get the Toshiba Universal 2 print driver to work as an IP printer and the Toshiba/Lexmark HBP printer driver to work via USB cable.
        • rthonpm
          • Aug 2007
          • 2847
          Honestly, I haven't installed a printer through the Control Panel in years. It's generally easier to just run printmanagement.msc and do everything through there. It's especially helpful if you need to pre-stage drivers or if you want to clean out old drivers without futzing around with multiple other tools or trash registry cleaners. It's also great when you need to add a driver to a remote computer as if it's on the same LAN and your account has admin rights, you can connect to the print manager of another computer.
          Overall I'm glad Microsoft is finally getting all of their settings into a single place instead of having to go three or four places to make changes.
          Sent from my Pixel 6 Pro using Tapatalk
            • 8137
            I will check that out. Thanks!
            • rthonpm
              • Aug 2007
              • 2847
              Originally posted by Angel17
              Such a lovely post. Thanks for sharing! Chevrolet Sherwood Park
              Thanks for the spam.
                • 37240
                Originally posted by jinji
                And in general, if we consider the best manufacturers, which ones would you consider the best? For example, if we're talking about MAC, which ones are cheaper and better in terms of features? I'm looking at this comparison here Comparisons, analytics, top rankings from RankQuality.com, but I'm not sure yet
                Go to hell spammer.
                • rthonpm
                  • Aug 2007
                  • 2847
                  And with nonsense like this on the rise, it seems that our little corner of the world is slowly beginning to die off.
                  • dickierock
                    • 252
                    Hiya,
                    What do you need to jump onto the remote pc? Is it \\ip address or computername?
                    How do you add the driver? Please describe this process if you don't mind, thanks.
                      • 37240
                      Originally posted by dickierock
                      Hiya,
                      Seeing as how rthonpm posted "as if it's on the same LAN" that indicates it is on a different local network. device name lookup is not going to work.
                      • rthonpm
                        • Aug 2007
                        • 2847
                        Let's answer two posts in one:
                        That should have said 'if it's on the same LAN', the 'as' was left over from a different thought. Editing on the phone, even with a good virtual keyboard isn't as clean or easy as a laptop.
                        I'll create a separate thread for how to use the Print Management console in Windows to install drivers on a remote machine, that way everyone has the steps right at the top instead of having to dig through a thread.
                          • 37240
                          That is why I only use my laptop. But then again I am retired so don't have to use anything else
                            • 37240
                            Federal Agency Warns Millions of Microsoft Users to Update Settings - Truth Press
                            • Hansoon
                              • Sep 2007
                              • 3367
                              โ€œ Sent from my Intel 80286 using MS-DOS 2.0 โ€œ
                              https://www.copytechnet.com/images/smilies/biggrin.png
