This might be a stupid question,
Re: This might be a stupid question,
Can you ping the printers? If yes, try and disable windows firewall or your antivirus programm.
If not, cmake sure to set dns and see if you can find printers using their dns name.
EDIT: You realy need to check if you are in a different ip-range as the printers. As long as both are connected with a lan cable it is however very unlikely that you are in a different ip range. You could check for the subnet mask but again, for home-users it is very unlikely that there is anything else than 255.255.255.0 configured.
It might be possibly that the pinters have a old gateway or dns configured though.
I would be willing to help you via teamviewer or anydesk if required. And as long as your Sister speaks german i can also directly offer support.Comment
Since the printers still have their 192.168.1.20 and -21 static IP-Addresses, there's no way for me from a distance of 600 km to change that. With TeamViewer, I am able to go into her laptop but as mentioned before the laptop got now via DHCP an IP-Address like 192.168.178.xx (Knowing that here issues could develop I set it to DHCP and did not use the old IP-Address.Now allowing me at least to use TeamViewer for support.)
As a last chance, I remotely hoped that I could use as a backdoor some obscure CMD-Command unknown to me.
For the moment, it seems the only solution to get into the router and change the IP-Range, but this is very risky since if anything goes wrong I have no means to enter her network again with Teamviwer.
Another better option is to send her the user manuals of the printer's highlighting the settings for a factory reset.
Thanks all of you guys for your support.
Hansโ Sent from my Intel 80286 using MS-DOS 2.0โ
https://www.copytechnet.com/images/smilies/biggrin.pngComment
Thanks, she speaks 7 languages including English and German, but no need for that. The problem is that the printer is not accessible through LAN because almost sure the provider did a reset of her router, changing by it the network settings. I had set it to 192.168.1.xx now it seems that the provider set it to 192.168.178.xx.
Hans
Changing the network seems too risky and overshooting for this case.
EDIT: Many Printers it is possibly to change ip address in menu too, no need for web-pageComment
- Change subnet mask to 255.255.0.0
- If you can then access the web page of a printer then either change its IP address or its subnet mask.
- Or if you can login to the router, change it LAN settings to the old subnet.
- Have your sister reboot her computer
Here is one thing to try while connected with TeamViewer:- Change subnet mask to 255.255.0.0
I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
Especially when it comes to sexComment
Just a thought. I have Chrome remote desktop installed on both of my laptops. I can access either one from the other regardless of where I am in relation to the other. I can also use it from my Android phone and tablet to access either laptop. It might be possible to walk her through installing it on her computer and then you could access her computer directly and make the settings that are necessary. Worth a try.Comment
