Paper Port
  • CopyTech03
    • Jul 2020
    • 54
    Paper Port
    In Paper Port I am able to add the TWAIN scanner (MFP) that shows up in the list, but when I go to scan it says Cannot Connect To Scanner. Tried rebooting PC, restarting MFP, and swapping out USB cord. Any other ideas?
  • rrrohan
    • Sep 2011
    • 1977
    Re: Paper Port
    why use TWAIN scanning and not a watched/monitored folder?
      • 37483
      Re: Paper Port
      Can you tell us what make and model MFP you are working with? Are you aware that most if not all MFP TWAIN drivers are 32 bit. They will install on 64 bit systems but need a 32 bit software to access them. I believe Paper Port is currently a X64 software.
      FAQ: Common Problems with x64 TWAIN Scanning.
      See if you can get a WIA driver for the MFP. Many MFP only have network WIA drivers available. WIA is what many dedicated scanners utilize
        • 30203
        Re: Paper Port
        Scan to a folder than add it to Paper port
        what model copier
        PS be sure the usb cable is 2.0
          • 37483
          Re: Paper Port
          what model copier
          The make and model are important here as not all MFP can scan to folder over a USB cable. Most modern MFP do have a scan to device option that support USB and SD devices.
