Two label printer USB connected to an A/B switch connected to a single PC via USB
    • 8211
    Customer is proposing the above, what are the problems?
    Wireless available via TCP/IP but at greater cost and complexity.
    No local cable drops. Long interior distances.
    • 8211
    Re: Two label printer USB connected to an A/B switch connected to a single PC via USB
    ... Two Toshiba wireless anterna/ board interface for a BEX4T2 label printer will cost about $1,200.00 installed.
    In an effort to get to a lower cost, I am wondering if I can use the NIC card interface built into each label printer to connect via network cable to a wireless bridge called A. Could Wireless Bridge A connect to the customer's existng wireless network?
      • 8211
      I have asked several people and they all say the same this set up is problematic and recommend a IP address solution via network cable or wireless adaptor.
      There are also bulletins from Microsoft that a recent update KB5015807 further breaks the reliability of USB printing.
      • mojorolla
        The Wolf
        • 2627
        If the distance is less than 300ft, cable runs would be your best (and most cost efficient) solution.
          • 37520
          If the printers have network ports, a WiFi can be used. Should be under $50.00 US each. StarTech makes a 1-Port Wireless N USB 2.0 Network Print Server for under $100.00 US each.
          How long is the total distance? It might be too far for USB. It not why use an A/B switch? Why not just use 2 separate USB ports on the computer or an external port expander.
          Most likely too far to use Bluetooth for one of them.
          • Samir
            Self-Taught
            • Oct 2023
            • 31
            A bit of a bump, but curious what you finally did for this customer...
