Another weird computer problem
    A customer brought in a laptop the other day. It was an older laptop but it was running Windows 11. I knew it didn't meet the proper specs to run windows 11. Apparently whomever they bought it from had manipulated the laptop in order to install Windows 11. Anyway, I decided to roll it back to Windows 10 by doing a fresh install.
    The problem I encountered was the hard drive that contained the operating system wasn't showing up in bios settings. Some of you may have seen this before but I haven't and it was frustrating to get it to work. Luckily I was able to find the solution online. What I had to do was manually add the drive.
    Anyone ever seen this before?
    Re: Another weird computer problem
    Afaik a legacy hard drive will not show up if the bios is set to UEFI and vice versa.
      It only affects bootable drives
        Are you talking about installing windows on bios vs. uefi?
        Note: Windows 11 was installed using Bios. I installed the new operating system -Windows 10- using UEFI. I had to reformat the hard drive to GPT. After the fresh install of windows 10, that's when the drive wouldn't show up in bios options, thus it would never boot. It would say "couldn't find operating source". Or something like that. I got it to work by manually adding the source.
          In my computer bios there's a hard drive boot mode ( or something like that ) you switch between legacy and UEFI.
          My computer has three bootable operating systems Windows, Linux and a Bliss OS ( Android for pc )
          Windows and Linux are uefi Bliss was legacy, The Bliss OS is not listed as a bootable device because it was installed legacy mode, and I use UEFI boot mode
          If I switch to legacy, I can only boot Bliss
            Windows and Linux are uefi Bliss was legacy, The Bliss OS is not listed as a bootable device because it was installed legacy mode.
            All bios are a little different between manufacturers. This particular one lists all the bootable drives. There's only one drive in this PC.
            I understand what you're saying but I installed Windows from a UEFI USB and selected UEFI in bios settings. Somehow the drive wasn't showing up and I had to add it manually.
              • 37235
              Most laptops I have owned that did not come with a Windows install disk came with the OS recovery on a partition. Try this Start Run diskmgmt.msc On the laptop am current using t shows a 100 MB EFI partition, a 237.36GB NTFS C: drive and a 1GB recover partition.
              Object moved
              • rthonpm
                • Aug 2007
                • 2847
                Object moved
                Ever since Windows 10 it's been so easy to get install media that there's really little need for a recovery partition. I've also been using business class laptops for over 15 years now where recovery partitions haven't really been a thing.
                Sent from my Pixel 6 Pro using Tapatalk
                • rthonpm
                  • Aug 2007
                  • 2847
                  You may also want to check that there are no BIOS or drive firmware updates for the machine as well.
                  There were a few line of Dells a few years back that would always lose the SSD randomly at boot. Took the updates to completely get rid of the issue.
