Unable To Connect Remote Desktop from W-XP to W10
  • Hansoon
    • Sep 2007
    • 3385
    Hi guys,
    I would like to connect with remote desktop from W-XP to W10, but it doesn't work. Opposite W10 to XP works fine. Are there any limitations, or am I doing it wrong?
    This XP computer is for safety reasons NOT connected to the Internet, otherwise I could use TeamViewer. TeamViewer using only local LAN doesn't work either.
    Hans
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
      • 37517
      Re: Unable To Connect Remote Desktop from W-XP to W10
      On the XP are you logged in as an administrator and does that administrator has a password?
      Is it XP Professional ?
        • 16395
        Originally posted by Hansoon
        Hi guys,
        Hans
        Am I understanding correctly that you're wanting to remote into a PC that is on your local network? I would think that is obviously the case since the XP computer isn't connected to the internet. What security concerns do you have?
        • Hansoon
          • Sep 2007
          • 3385
          Yes and yes.
          • Hansoon
            • Sep 2007
            • 3385
            Billy I don't have any security issues, but in XP it says:
            "The remote computer requires network level authentication" or WTTE
            So obviously XP does not have NLA or so...., though it's XP-Professional
            Hans
              • 37517
              You may have to install a third party application.
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                Check this link out. It may help:
                Attention Required! | Cloudflare
                • techsxge
                  • Jan 2022
                  • 660
                  Are both Windows Versions correctly licensed? Do you have Pro verison for both? Activated Remote Access on both machines?
                  There should be no other setting needed.
                  Others have mentioned to deactivate NLA, you can do it my test showed you dont have to:
                  • eddies
                    • Oct 2023
                    • 4
                    Hi guys,
                    Hans
                    Step 1: Log in as an admin
                    You can use any account that has local administrative rights.
                    Step 2: Check for update compliance
                    For Windows XP to be able to use NLA, it must first be updated to SP3. Additionally, I suggest installing the RDP v.7 update as well.
                    Step 3: Open the registry editor
                    Run regedit as Administrator.
                    Step 4: Navigate to and modify the registry keys
                    There are two keys to change. The first is located at:
                    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Lsa
                    You are going to modify the key named 'Security Packages' Add 'tspkg' to the listing of security packages. Do not remove any packages.
                    The second key is located at:
                    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\SecurityProviders
                    You are going to modify the key named 'SecurityProviders' Add 'credssp.dll' to the listing of Security Providers.
                    Close regedit.
                    Step 5: Restart the computer.
                    After the restart is complete. Test the NLA functionality by attempting to RDP to a server that only accepts RDP connections from machines that use NLA.
                    • Hansoon
                      • Sep 2007
                      • 3385
                      Close regedit.
                      Thanks, unfortunately didn't work.
                      Hans
                      • rthonpm
                        • Aug 2007
                        • 2859
                        100% not the answer... RDP and SMB have nothing to do with each other.
                        Part of the issue is a series of security hardening updates that Microsoft has made since XP went end of life.
                        Are you trying to connect via a hostname or IP as both methods use a different authentication mechanism, however both Kerberos (hostname) and NTLM have been hardened. You may want to confirm if TLS 1.0 is enabled on the Windows 10 machine as it may just be trying to use a stronger cipher set than the XP box can negotiate.
                        Your best bet may be, if possible, to virtualise the XP system and access it through the hypervisor's console. Of course, if it's connected to physical hardware of some kind that throws that idea out.
                        • techsxge
                          • Jan 2022
                          • 660
                          Atleast with my test windows xp vm upgraded to SP3, i can confirm that the rdp works. When using thip address i dont even have to disable NLA. Shouldnt this be the other way around?
                          • Hansoon
                            • Sep 2007
                            • 3385
                            XP to W10?
                            W10 to XP is working very well since long without any corrections had to be made. Just activate RDP with one click, but the opposite direction does not work whatever I do and that's what I need too. Reason is, that we have a very old but very good inventory software that works only with XP. This computer is in one of our warehouses, and it would be very convenient if it can be used too to RDP in the opposite direction to our main computers in the remote office.
                            An update to the inventory software would cost, including adapting old to new, around 10,000 Euro which is too much for this purpose. It runs with MSDE SQL whatever, software in the background. All attempts to lift it to higher Windows operating systems failed. That MSDE SQL server wants XP, nothing else. Virtual XP doesn't work either. It is not accepting that damned MSD-SQL thingy.
                            I could of course put another W10 computer beside the XP one overthere, but that is against my technical pride.......
                            Hans
                            • techsxge
                              • Jan 2022
                              • 660
                              XP to W10?
                              Hans
                              In my testing I was able to go in both directions without any issues. Maybe you are not on SP3? Or there are firewall rules in place that block the connection.
