Xerox Print and Scan App
  • richs
    • Nov 2008
    • 261
    This App use to be great.It would install with the driver and would be an easy and simple scan solution.Now it does not work most of the time and if it does I have to uninstall and reinstall it many time to get it to see the machine and work.Sometimes have to uninstall all other scan Apps .Any solutions out there?
  • Proman
    • Dec 2023
    • 5
    Re: Xerox Print and Scan App
    There may be driver issue. Use the print driver to take full advantage of your printer's features. PCL5e, PCL6, Postscript and XPS drivers are available.
    • richs
      • Nov 2008
      • 261
      The print driver does not do a good job scanning.The app use to be great .It installed with the driver and work ok as long as you were close to the machine.
