.heic file format
    • 8143
    .heic file format
    I ran into this new to me file format today trying to print colour images.
    .heic = High Efficiency Image File Format. Apparently if you double click them they turn into a JPEG format.
    The images were taken from the latest Apple iOS15 phone.
    Windows 11 Photo viewer would not allow me to selct the OEM print driver that I wanted to use. I could only use a generic Windows print driver. The customer was complaining that flesh tones were blotchy red.
  • Hart
    • Feb 2024
    • 372
    Re: .heic file format
    Looks like you need an official app to add HEIF to Windows Photo Viewer :
    The HEIF Image Extension enables Windows to read and write files that use the High Efficiency Image File (HEIF) format. A video extension package must also be installed in order to view images that are stored in the HEIF file. The HEVC Video Extensions package must be installed in order to view images stored in HEIF files that use the .heic, .hif or .heif file extensions. The AV1 Video Extension package must be installed in order to view images stored in HEIF files that use the .avif file extension.
    It's free contrary to the HEVC extension.
    I don't see how it's going to be popular (I've never heard of it before) when AVIF is already struggling (and we don't talk about WebP).
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
        • 8143
        I think the .heic files are being automatically generated by a new, latest iPhone 15 setting.
        I did remotely install IrfanView on the customer's Windows 11 Home computer. The customer connects fron her iPhone via USB cable to see the images and select what to print.
        The images on her computer I can open in IrfanView no problem.
        The images on her iPhone resisit being opened in IrfanView.
        • Hart
          • Feb 2024
          • 372
          This is not the default format on iPhone, your customer purposefully choose this format (like on Android you have to select HEVC H265 instead of the standard H264 for movie recording).
          Utilisation de fichiers multimedias HEIF ou HEVC sur les appareils Apple - Assistance Apple (FR)
          Also yes browsing and opening files from a phone plugged in USB is a mess on Windows (probably because it's still using this old MTP protocol but I'm not an expert)
          Media Transfer Protocol - Wikipedia
            • 37323
            Irfanview does not currently support the .heic container format. The files on the computer were probably converted when downloaded. This might help. What is HEIC file, and how to convert HEIC to JPG?
              • 37323
              IrfanView and HEIC Compatibility: What You Need to Know. IrfanView and HEIC Compatibility: What You Need to Know - SoftHandTech.
                • 8143
                I now know that .heic is a new file format released by Apple found on the newest iPhone 15.
                I will test later today if AirPrint can print .heic files.
                The latest Toshiba copier releases actually require a certification from Apple to work with .heic .
                Toshiba has released both a firmware patch and a new FW1810 to enable AirPrint to wotk on the latest copiers.
                I have found a pirce of software called Print Conductor $99.00 USD that claims print compatibility with .heic files.
                How to Print HEIC Photos - Print Conductor
                ... that I need to test.
                  • 37323
                  Actually in 2017 when iOS 11 was released Apple made it the default for photo storage. iPhone 15 was not released until September 2023.
                    • 8143
                    A big part of the problem with this customer is the user is not tech savvy.
                    Part of the struggle is getting .heic photos from her iPhone into her Win 11 PC.
                    Her current process is a multi step and involves a USB cable.
                    I think using iCloud as in this video will help simplify the process.
                    How To Transfer ANY FILE Between iPhone and Windows PC (FREE!)
                    How To Transfer ANY FILE Between iPhone and Windows PC (FREE!) - YouTube
                    The customer is one woman business that is a craft retailer that does craft shows that needs to print good quality images from her iPhone 15. Buying a Colour A3 laser copier is a big expense for her and she has high expectations.
                      • 8143
                      This might be a better mthod to transfer files from an iPhone to a PC as it does not involve the use of iCloud.
                      How to Transfer Photos, Videos & Music Between iPhone & Windows PC | No iTunes or iCloud
                      How to Transfer Photos, Videos & Music Between iPhone & Windows PC | No iTunes or iCloud - YouTube
                      • Hart
                        • Feb 2024
                        • 372
                        Just tell her to change the default file format to JPEG (or whatever is the default), AFAIK it's only the size that will suffer, not the quality.
                          • 37323
                          If she is wanting good quality prints,she needs to get a good quality color printer.
                            • 8143
                            ... that does not help with the many pictures she has already taken but it is a good idea going forward.
                              • 8143
                              ... I would not be doing all of this work if she had not recently bought an excellent quality Toshiba colour copier.
                              It has been a good learning curve into the Apple world of printing high quality pictures.
