Typical SMB and email stoppers
  • jeffreyclay
    • Sep 2008
    • 44
    Hi all, I've got a new KM C353 in a government facility. (The servers are 1000 miles away and information and detail requests fall on deaf ears) SMB scanning fails with server connect errors, emails never go through. Print jobs are ofcourse successful. I haven't made a packet capture yet (mind was foggy with flu last visit) But I wanted to ask what security measures would block these protocols? I had the mac address registered with the router. I can't even hit the Yahoo.com mail server. I'm told no authentication is needed for a yahoo connect yet I had a similar customer had some security protocol that their older Ricoh didn't use (and was successful) but a newer KM did (and wasn't successfull) and we changed the order of sequence for checking. I've forgotten what was resequenced. It was done on the mail server. Does this sound familiar to anyone?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    They may have smb turned off or have the ports associated with smb blocked.. Been there done that. They may or may not open them but it is easier to get congress to agree on something unanimously...
    • TheOwl
      • Nov 2008
      • 1733
      Just as a test to make sure you don't have a DNS issue, try pinging Yahoo's or Google's IP address rather than their DNS name from the copier.
      If you get a response then, you will know that you are having issues with the DNS on the machine.
      • jeffreyclay
        • Sep 2008
        • 44
        Copier does ping yahoo mail. I wasn't aware you could cut off SMB protocol on the switch or network. I'll have to check on that. Thanks for your input.
        • unisys12
          • 490
          Since your dealing with a WAN, don't forget about firewalls.
          Also, make sure your gateway address is correct. Remember, the gateway connects to two networks LANS to make a WAN.
          One other thing, check and see if they are using WINS. You can check this by performing IP config on a client PC. If they are, then program that info into your MFP. I'm sure it supports it. You can get the IP addresses from IPCONFIG, but to get scope and stuff like that, you will have to go into the Connection Properties under network connections.
          sigpic
          The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
