PI 4700e
+ More Options
Posts
  • poz31
    • Aug 2006
    • 86
    PI 4700e
    Is there a way to set up this scanner with authentication settings????
  • RyanPacific
    Linux Ninja
    • 97
    Unfortunately the Pi series does not have an option for authentication. I've had similar problems recently with this exact controller. The scan function especially with e-mail is very limited. You will probably also notice that there is no option to change the port either. So another problem is that an e-mail server using a non-standard port (not 25-SMTP) will also not function with the controler. I have observed the majority of SMTP servers I work with are on non-standard ports with encrypted authentication for obvious security reasons. The only real solution is to set up your users with access to the WebScan tool and hope and pray it doesn't fail on them, unless of course you can manage to sell them newer more versatile equipment.
    Service Business Equipment
    New, Used, Refurbished Copy Machines and Printers
    Copiers in Seattle, Kent, Tacoma and Bellevue
    • jneezy2008
      Software/IT
      • Mar 2009
      • 72
      Another option, if the customer is up for it, is to install ArGoSoft Mail Server. It's very lightweight and easy to configure. There are only a couple of more steps for the customer to retrieve their scanned documents but it's better than nothing.
      But upgrading is always a better option.
      The snozberries taste like snozberries!!
