Microsoft Vista
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    #16
    I've noticed a few firmware updates trickling through for various Ricoh MFPs to fix some scan to SMB issues when using Vista.
    • Johnny Bravo
      • Mar 2007
      • 12
      #17
      Well I upgraded last night and it went OK. I had one error when I was all done and there is was a pretty easy fix. The new interface is very easy on the eyes and it has some cool new features. I haven't had too much time to play with it so I will follow up in a few weeks if I run into anything.
      • MrCMYK
        • Mar 2005
        • 14
        #18
        from what I've seen & herd, most Fiery RIPs don't have Vista 32/64 (or XP64) drivers. EFI is always very late on coming out w/ drivers for new OS's, its like they are the last to know. Most are never certified. The projected release dates are strewn thru-out the next 6-7 months... Vaporware... look for those dates to push.
        Customers are starting to upgrade / buy new computers and have been asking about drivers.
        Try XP drivers or OEM manufacture standard controller drivers and lookout for wierd problems... give the customer a disclaimer
        • Scott_Lewis
          • Mar 2007
          • 519
          #19
          We've recently replaced two of our shop desktop pcs. One of then has Vista Ultimate loaded simply because we wanted one for experience and training.
          The score at this point is one graphics program that won't run, one explorer type utility that mostly runs, and ALL printer drivers installed to date are crippled.
          All of the printer/copier drivers installed so far are of the 'mini-driver' variety simply because the normal PCL drivers are not available ..... yet!?! or not Have not tried any PS drivers to date. This wasn't so much a test as it was an attempt to link with machines we have connected for our printing needs.
          Scott
          • DallasTech
            • Feb 2007
            • 119
            #20
            I did have some luck with a Di470 with a Fiery X3e. I just installed the XP drivers on the Vista machines and actually installed Remote Scan 5 to pull scans from the Fiery box. Everything was working fine, but I don't know if it was 32 or 64-bit. I haven't heard a complaint from them yet, but their IT guy is knowledgeable enough to know it's not going to be perfect. This was over a month ago and I haven't got a call back.
            • Dukem
              #21
              I have Vista loaded on a removable drive on my home PC so I can experiment with it and keep my original configured XPpro system as my everyday use OS.(That and my wife hates it when I change everything just when she gets used to it!) I have found out several things while testing Vista:
              1. It doen't like to be in a multiple boot environment.
              2. It is a resource hog
              3. Make sure programs are compatable before loading - if possible
              4. There are (too) many tweeks that can make it faster
              5. I'll wait for about a year before I make it my standard OS (If at all!)
              • MrCMYK
                • Mar 2005
                • 14
                #22
                well, vista's SP1 is out now. I am setting up a system and loading my aps. Takes a little bit getting used to, I am surprised to see soo much stuff still running on beta drivers... man, its been a stinking year! Oh well, I guess I should have known, we still don't have the Fiery drivers for all the current models either.
                so far, my card reader is the only casualty for hardware. Software is weeding out the stuff I haven't used regularly
                • techathens
                  • 83
                  #23
                  Stick With Xp Or Xp Pro Or Even 2000!
                  Salesout Pro
                  SalesoutPro@gmail.com
                  • fausto1981
                    IT Technician
                    • Dec 2007
                    • 145
                    #24
                    Yeap, Same here
                    sticking with XP Pro after experimenting for a minute.
                    • MrCMYK
                      • Mar 2005
                      • 14
                      #25
                      well, I have been playing w/ vista for a while now... I get several " windows, run.dll, outlook, explorer, windows update stopped working" error messages a day.
                      Me thinks its time to roll back to XP.
                      the "Vista Sucks" video is right, it just plane sucks.
                      Uncle Bill, you are on my VISTA list ;-)
                      • djbass
                        • May 2008
                        • 165
                        #26
                        I laugh when I read most of this because 99.9% of it is utter toss.
                        Vista is a very stable and well rounded OS. It is not buggy, still in beta, a resource hog or the spawn of satin.
                        My home system has been running it since release and it is been rock solid for the majority of that period. There were some performance/stability issues in the first couple of months but that wasn't Vista's fault, rather the driver vendors for still having beta drivers at Vista's launch.
                        It is true that it consumes more memory than XP does but for the most part that is a good thing as its part of the prefetching feature and improves the more you use your PC, it also dynamically allocates more memory to programs as needed.
                        I have about 8 months ago purchased a laptop preloaded with Vista for service work and have not encountered any compatibility problems for the most part.
                        Vista doesn't suck, its just different, and the sooner people learn its not just a prettier XP but a whole new OS the better.
                        No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
                        • wingnut132
                          • 65
                          #27
                          I agree with djbass, I was beta testing it since the get go, have 3 new systems with vista and a couple of upgraded sytems from xp, all works fine with no issues never crashed and I did try when beta testing, vista is alot nicer than xp, just wait until windows 7 comes out people will still bitch. You have to move on and come out of the dark ages.
                          • MrCMYK
                            • Mar 2005
                            • 14
                            #28
                            I do like a lot of the features...
                            but after being on the computer for 20 min today...
                            when i logged in, I was greated with 2 "sidebar stopped ..." messages
                            I checked email (outlook 07 w/ all updates), went well.
                            I hit the link in copytechnet's email to take me to hear, IE7 crashed... stopped working msg.
                            then a "windows update stopped working" msg.
                            on the puter 20 minutes and had 4 errors. Oh yes, sometimes when I get one of these "xxx stopped working msgs, my taskbar and window frames turns white and my theme is changed, I must reset to my default to fix.
                            "Its not a bug, it's an undocumented feature" ;-)
                            my system is a homebuilt system. all the hardware is vista cert, w/ oem vista drivers. MS office 07 w/ all the updates, vista ultimate 32bit w/ SP1 and all the updates.
                            due to it being a new system and I have been testing / learning the only non MS software I have is quicken 06 w/ vista update.
                            I frequent the mom & pop computer markets/stores and most are having trouble w/ vista and xp outsells vista.
                            I have also been pokin' around on the vista PCs at the big stores... HP, Dell, Tosh ETC. it does seem like the big named PCs are running more reliably than the homebuilts... perhaps those people are the ones that are living large on vista
                            • djbass
                              • May 2008
                              • 165
                              #29
                              I have found stability problems to be driver related, certified or not it seems there must be some fundamental change to the driver structure that vendors are having trouble getting their heads around.
                              As an example I started out with Vista running on an Abit mobo and it never skipped a beat, as Abit generally are very good with their drivers.
                              I recently upgraded to a Asus mobo to get support for the newer 45nm processors and have had a couple of issues due to buggy drivers, every other bit of hardware is unchanged.
                              I would say that is the same reason the big named PC's run reliably as the out of box drivers have already been tested and tuned specifically for their hardware under Vista.
                              You have to remember XP has been around 7 years now and vendors have had plenty of time to get used to its quirks, it wasn't smooth sailing at release either. If you really want to wait another 7 years for Vista to reach the same equalibrium go right ahead but we will be staring down the barrel of Microsofts next OS by then
                              • Steve Perks
                                • Mar 2008
                                • 32
                                #30
                                I've been running Vista Ultimate for a few months now.
                                The install/fine tuning wasn't a painless exercise but soon got everything ironed out.
                                It has worked flawlessly ever since.
                                I was originally running with a P42.8ghz processor and 1GB RAM.
                                I've just built a new machine with a Core 2 dual 2.2ghz and 2gb RAM and Vista is now flying.
                                I'm one of the minority that loves it.
                                Team Leader/Technical Specialist: CMYK Digital Solutions Ltd
