Why doesnt this print job leave the print queue?
  • scoobysteve
    • Jun 2008
    • 163
    Hi All,
    I've got a client who has a Kyocera FS-1920N printer who prints a 1 page document for 300 clients of theirs at the end of month - although not a batch print. All these documents are printed in very close succession.
    the clients have informed that the print queue is giving a "print job failed" error.
    What gets me is, a 1 page document isnt normally large enough to hold up the queue and normally processed quicker than the eye can see, thus the printer should be pumping through the jobs.
    So, i created a 200 page document in MS Word and printed it to this printer. The job spooled to 350kb of 350kb and then stayed in the queue while the printer was still printing out the pages of the document. I would have thought that when it has finished spooling, the job will clear the queue even though the printer is still in the process of printing out the document.
    Because of this scenario, all other jobs behind it in the queue must time out? as then the status of the awaiting prints says "Error - Printing"..
    Anyone know where i should be looking?
    I've loaded latest drivers, latest firmware, tried different network cable, different network port and still the same problem? printer or network problem?
    Any suggestions would be great. thanks.
  • Wynard
    Used to be a Tech
    • 42
    You could try to
    - manually stop the spool service, empty C:\WINDOWS\system32\spool\PRINTERS (but do not delete the folder itself) and then restart the spool service. Might clean out some corrupted data that still hangs around and hinders normal operation.
    - update the firmware. I think the problem is the printer. It happens every day that some printer somewhere just ceases operating normally because the firmware got corrupted some way or another. Firmware updates can be miracle cures
    Hope this helps.
    Since the creation of the internet, the rotation of Earth has been powered by English teachers spinning in their graves.
    • scoobysteve
      • Jun 2008
      • 163
      thanks for your reply...
      I've got each pc printing to directly to the printer (not via share) and each one has experienced that problem so i wouldnt think that it was driver related - so hopefully i shouldnt have to clear the files in the spool folder.
      I've updated the firmware and supposedly the problem is still there although during my visits to this client, all seems to be ok.
      I've changed the Network card on this machine as a test as yesterday was meant to be the biggest run of prints for month. I didnt receive a call back so fingers cross, hopefully it is a bad NIC - although saying that, a continous ping test was successful even when the print job had failed.
      well, anymore suggestions would be greatly appreciated. thanks
      • unisys12
        • 489
        Have you checked for packet loss?
        I had one the other day that drove me nuts... I could send a test print, from the driver, and it seemed to print just fine. I did notice though that the printer icon in the system tray was there a bit longer than it should. Anyway, when trying to print a simple page from notepad, I got the print failed message. When I checked the que, size of the job was not the same as what was sent to the printer. In other words, the document was 7kb and the que showed that it had only sent 6.8kb. The MFP was basically locked up at this point as well, waiting on the last part of the file.
        I ran "ping (ip address of the printer) -t " and found that I was looseing several packets in small amount of time. You can tell this by recieveing a response for several returns, then nothing, then recieve a response again. I also noticed that the times varied quit alot too. One response might have been 3ms and the next might be 120+ms.
        Just something to look for. By the way, it was a bad cable running from the upstairs router.
        sigpic
        The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
        • schooltech
          School District Tech
          • Jun 2008
          • 504
          Unisys, this is a great find and explains something I've said for quite a while, which is that not all problems are that difficult. It just takes a bit of efficient, effective troubleshooting skills to identify the problem.
          Scoobysteve, you could have one massive collision domain, and something on the network might have recently changed and making it even worse.
          Did you use a x-over cable and print directly to the printer, rather than go through the network? I know you said that you changed the cable and switched ports, and I assume that the cable you switched is still going through their network.
          Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
          • Vulkor
            • Jun 2009
            • 946
            Yep what I do when I have issues. CROSSOVER CABLE... to my Laptop.
            Or I bring my own router and wire it up, run a ton of data from large print jobs. and also continuous pinging. Its how I discovered the problem of the Wireless Print Server being the problem and not the copier before.
            • scoobysteve
              • Jun 2008
              • 163
              Hi All,
              thanks for all your input..
              I havent tried the crossover cable to laptop as i could not replicate the fault that they were experiencing and even when i did see a fault, i dont even know if it was the same problem as what they were getting. this problem is so intermittent.
              the clients said to me "it had been playing up all day and right up to the hour before you got here"... then while i was there (for 1.5hrs) not one fault...
              Anyhow, when the machine did fault for me (whether or not it was the same problem as what the client had seen), i had been already running a continuous ping and it was replying consistently for about 5 mins - not one drop out.
              With what unisys12 said, my spool file size and the size of data that was being sent out was actually reaching the right size, ie 304kb/304kb but just wasnt exiting the queue. Whether or not this is because the NIC isnt sending back an "ACK" message to the PC or vice versa, who knows...
              anyhow, since i've changed the NIC, the client hasnt called back just yet..i'm going to leave it for most of today and then see how they went..
              by the way, i've spent 2.5 hrs there so far, and i can guarantee, they will not pay for the total time spent... i reckon even half of the labour charge will be difficult...
              • Vulkor
                • Jun 2009
                • 946
                Don't you hate when calls take too long and customers won't pay the bill. Sometimes gotta cut your losses.
                • Captain Scott
                  • Dec 2008
                  • 166
                  A memory leak occurs in Windows Server 2003 when you send multiple print jobs to a lo
                  I had a similar issue and a hotfix for Windows Server 2003 fixed the problem. See below link for more info http://support.microsoft.com/kb/883673/en-us . Hope this info helps someone, it took me days of testing to get to this point. Changed controller ect. One other thing you could try is to use the LPR port instead and test results (unix print services for windows)
                  • schooltech
                    • Jun 2008
                    • 504
                    Good find----thanks Captain.
                    • scoobysteve
                      • Jun 2008
                      • 163
                      hi All,
                      the only problem with the windows patch is that i dont have printer setup through a share anymore (ie, everyone prints via tcp/ip) and i still get that problem..
                      • Captain Scott
                        • Dec 2008
                        • 166
                        LPR
                        Are you able to test using the LPR port instead of TCP/IP. Will need to add windows component : Print Services for Unix under other print and file services.
                        • scoobysteve
                          • Jun 2008
                          • 163
                          hi,
                          i havent tried using a lpr port. i've configured a tcp/ip as a "emulated" lpr port.
                          maybe that might be something i should look into - however, saying that surely not all pc's that print to it would be experiencing the same problem..
                          • Captain Scott
                            • Dec 2008
                            • 166
                            Is it happening daily?
                            Do you have any other printers or multi-functionals at this site. Compare ethernet speed setting and move the faulty device into its position as a test for a few days. You could also place a small switch/hub between the data point and hub as another test. Good luck these are the worst! Sometimes a paper jam will prompt the user to say its happening again
                            • skinnypuppy
                              CopierJanitor/Geargluer
                              • May 2008
                              • 92
                              Try KX driver
                              I have resolved many print issues on the kyocera's by simply installing the KX driver located on the their website. And changing the PDL from PCLXL to PCL5. The default on this driver is PCLXL In the driver properties\device settings\PDL. Also if you have Ram disc set to on and are using it set Ram disc to max 1/3 of Memory.
                              Hope this helps
