Connect Toshiba E-studio 45 To My Network Using Macs & Airport Extreme
  • daelementz
    • Jun 2025
    we have had this E-Studio 45 for about a year now. i really want to connect it to our network so we can just print directly from it. we do alot of brouchers, and posters, and other promotional stuff, and it would be alot better if we could directly print from this machine other than going to kinkos. can someone please direct me to a site or please give me some insight on how to link it all together and get this machine printing from our MACS. any help will be appreciated.
    daElementz
  • lanelander
    I have a need in Chicago...
    Is there anyone that can assist with a 45 as well in the Chciago area?
    PM ME
    • copyguy5
      Which Controller Do You Have?
      Do you have the GA1040 or the GL1010? Post your answer and I'll direct you to the correct information.
      Is there a DB15 Video connector?; is there a Mouse Connector?/Keyboard Connector?
      Copyguy5
      • daelementz
        GA1040
        WE HAVE THE GA1040. I DONT THINK THERE IS A MOUSE OR KEYBOARD CONNECTOR ON IT. OR A VIDEO CONNECTOR. IT IS JUST THE COPIER. PLEASE DIRECT ME TO THE RIGHT PLACE, I WOULD REAALLY APPRECIATE IT. THANK YOU AGAIN.
        daElementz
        • copyguy5
          Ga1040 Toshiba Print Controller
          The System Software can be downloaded from:
          This file should be "Burned" to a new CD ROM and the used; either by runni ng from the CD or copying to a temporary folder on your computer.
          Both Disk and Diskless software is included.
          The Service manual is at:
          GOOD LUCK
          copyguy5
          • daelementz
            Service Manual
            thanks copyguy5...i really appreciate the time you have taken to send me what i need. i tried downloading the service manual, and all i get is a bunch of text. no service manual. will the service manual tell me how to hook it up to the network. and another question is. do i need a static IP for the copier.
            daElementz
            • copyguy5
              GA1040/eSTUDIO 45 DOCUMENTATION
              Sorry:
              I neglected to send the user documentation link
              Index of /protectedmembers/201519/eS45UserDoc/Englishv11
              When setting up a network I preder to assign a static IP to each device on the network. Just my personal preference.
              If yor're not real comfortable with network setup let me know. I have a couple of very informative setup routines which I will try to dig out.
              Good Luck
              copyguy
              • daelementz
                Network Setup
                i have tried setting it up on the network, and i could not get it to work. please send me whatever you got on this topic. like i said i appreciate all the information you have been supplying me...thank you.
                daElementz
                • copyguy5
                  Net Setup For Toshiba Copier- Windows Xp
                  The link gives a simplified Net setup process. It is only intended to give a general overview of a simple configuration. Although it does not show your model the procedure is the same.
                  You should print out a configuration sheet from the copier touch screen.
                  Refer to the Configuration Guide.
                  I assume you are using WIN XP. Correct???
                  Here is MS Support link
                  How to set up a small network with Windows XP Home Edition (PART 1)
                  Good Luck
                  copyguy5
                  • daelementz
                    MAC OSX
                    im actually running MAC OSX...that is why im having alot of trouble, because alot of people dont know how to set it up with the MAC.
                    daElementz
                    • copyguy5
                      MAC OSX
                      The drivers are ast:
                      Index of /protectedmembers/201519/GA1040drivers
                      There is a procedure for setting up the MACS. I'll dig it out and notify you of the link.
                      copyguy
                      • daelementz
                        GREAT...
                        i really appreciate it, just let me know when and if you find the procedure...thank you again for everything.
                        daElementz
                        • Ctl-Alt-Del
                          • Jul 2006
                          • 430
                          You could have told us that a little sooner. Good Luck!
                          • daelementz
                            Check The Title Of The First Thread
                            i actually did...when i first posted the thread, i mentioned i was running MACS and Airport Extreme. sorry if i did not make it clearer...my bad.
                            daElementz
                            • Ctl-Alt-Del
                              • Jul 2006
                              • 430
                              Nope, My bad, I missed it in your original post.
