How do you setup shared folders on an as400 so that they are accessible from a copier... ???
As400 shared folders???
You can send files to the AS400 using FTP, (SMB will not work) just as with any other host (Windows, Mac, UNIX, etc...)
You'll need to work with the AS400 admin to set up folders and give you the paths to use. If you don't, the scans will all end up in a default folder. I'm not sure what that folder name is offhand.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim Hawkins
