I to setup the Ricoh using Gmail SMTP, but there is no option to enable SSL like the Konica, I don't know what else to try, Usually at times like this I would setup IIS in a Windows XP pro or 2Kpro and add the IP address on the relay and that solves the problem but this customer only has a P2P with a laptop and two other XP Home PCs.
I would really like to know if any of you out there have had the same problem that im having right now; and if possible please tell me how you got around it because i really need to get a solution for this.
