Bizhub C450
  • stevee104
    • Mar 2007
    • 214
    Bizhub C450
    can not get a equitrac system to work on this machine.have service manuals,owners manuals and even talk to customer service at equitrac
    and still no go.we are not a minolta dealer so any help would be
    great. thanks steve
  • knightfall
    • Jul 2006
    • 633
    1. Remove the Finisher.
    2. Remove the Left side Cover, inside is located a 4 pin connector
    3. The correct key counter mounting kit used with the Equitrac key counter devices is (Item #4623481).
    4. The correct copier interface cable is included in the kit.
    also attached is billing setting to configure you equitrac to c450
    good luck
    Get your facts first, and then you can distort them as much as you please.
