Ricoh MPC2050 - Unable to scan to SMB after update on Win7 x64
+ More Options
Posts
  • mrwho
    Major Asshole!
    • 4299
    Anyone got trouble scanning via SMB from a Ricoh box after Windows7 64 bit updated itself?
    A colleague of mine tried all the tricks and somehow he still can't scan - just to know if anyone else has this problem.
    Cheers!
    Mascan42
    Ibid
  • Vulkor
    • Jun 2009
    • 946
    Ya know I haven't tried in a bit, so I tried today and yep. Win 7 X64 SMB Scanning is not working. Tried on brand new Savin C5050 with newest firmware. Log in but cannot find specified path. Same with a C2525
    The XP Pcs can still access the Share on my Win 7x64, but not any copiers.
    • Vulkor
      • Jun 2009
      • 946
      FOUND The Answer, It is Knowledge Base ID#119589
      When selecting the target PC on the [Browse Network] screen, "Cannot find the specified path. Please check the settings." is displayed.
      The personal firewall is open. It is possible to access the shared folder on the Windows 7 PC from another PC.
      How can I fix this?
      The problem is caused by the difference in dependencies when the network connection is established by SMB. (Windows 7 requires Samba 3.0.23 or later but the device only supports an older version of Samba.)
      Try entering the folder path manually, as follows:
      \\Computer Name\Folder Name
      I tried doing it manually instead of browsing and it worked, cheers
      • mrwho
        Major Asshole!
        • 4299
        Thanks. I'll pass it on to my colleague who's having the problem.
        Cheers!
        Mascan42
        Ibid
        • nobody-here
          • Mar 2008
          • 237
          Did you solve?
          We are looking for other infos, because we're having trouble with Win7.
          We have 2 PC with win 7 and 1 MP2000. One to 1 PC Scan works great, to the 2nd is not working (same PC, same installation, same Softwares)
          We are thinking of a Mac Address BlackList.
          Same network, same workgroup, we already checked: IP's Username & PWD, Firewall, Antivirus and Other f...ing Stuff.
          Permission folders are ok.
          If you can help us, you will win a free Sicilian "Granita".
          Best Regards!
          Vincenzo
          29 rouge unpair manque.... cous cous....
          • Vulkor
            • Jun 2009
            • 946
            If EACH PC is exactly the Same Version of Windows 7, and have the Same Firewall, Same Security Settings and such perhaps spyware or a Virus. MAC ADDRESS Blacklisting is usually used on Routers. Can the PC that cannot scan see the shared folder of the other PC?
            • Stirton.M
              All things Konica Minolta
              • Oct 2009
              • 1804
              Is the problem child perhaps Windows 7 "Home"? If so, that could account for some of the problem.
              Another might be the network profile, is it public, home or work on the computer. This can affect how your computer is "seen" by other devices on the network.
              "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
              ---Groucho Marx
              Please do not PM me for questions related to Konica Minolta hardware.
              I will not answer requests or questions there.
              Please ask in the KM forum for the benefit of others to see the question and give their input.
              • nobody-here
                • Mar 2008
                • 237
                We didn't check Spywares , we'll try,.
                It's Windows 7 Professional, with private network (we checked every option)
                It's weird!
                • mrwho
                  Major Asshole!
                  • 4299
                  We just gave up on that - installed Filezilla Server and went via FTP.
                  Thank you all for your replies.
                  Mascan42
                  Ibid
                  • aabarnes1
                    • Mar 2009
                    • 620
                    Can you mail me the details please or pm them thanx, aabrnes1@gmail.com
                    Grant me the serenity to accept the things I cannot change.
                    • mrwho
                      Major Asshole!
                      • 4299
                      I really don't have the time now to make a detailed how-to, but we basically installed Filezilla Server onto the customer's troublesome PC and then, after creating a user with password (user:scan password:scan) and assigning a home directoy (desktop/scan) with write permissions, we configured the machine to scan via ftp.
                      Mascan42
                      Ibid
                      • john-halo
                        I was helping another connectivity tech with this same problem on a Lanier (same as Ricoh/Savin/Gestetner). Small difference though is we could scan to folder fine to all 32 bit Win 7 boxes but not to a single Win 7 64 bit box. I had tried the suggestion above about using the UNC path instead of browsing and it does not work on the 64 bit systems. We ended up setting scan to email for those users on the 64 bit systems.
                        • BlackSun
                          Try this
                          I just had the same problem on a C2050 last night and finally got it figured out Ricoh tech bulletin #037 for the machine had a note for a different problem. My customer updated windows and the scan to SMB quit working after 4 hours of troubleshooting I went into the programs menu and deleted Windows Live ID Sign-in Assistant as soon as I did that I was able to scan to SMB.
                          I also had to make sure that the destination folder Ownership was set to administrator and it had full access.
                          Hope this helps.
                          • craig
                            service manager
                            • May 2010
                            • 23
                            win7 X64 bit uses port 139 for services, causing smb errors.try using port 445.
                            • john-halo
                              Would you change the SMB port in the SP codes Craig? I just saw your location is Beaverton. My oldest son works for FedEx and lives in Beaverton. Beautiful area from what I have seen.
