problem connection between PC (windows 7) with Canon IR5570
  • sikuswo
    • Sep 2025
    Dear all,
    I need your help.
    I have canon IR5570. my computer use windows 7 32 bit. conection with lan cable.
    That i have done :
    1. Ping canon from PC. success.
    2. Ping PC from canon IR5570. Failed.
    3. I install CanonDriverConfigToolv3_32BIT.exe
    Canon U.S.A : Disclaimer
    success.
    4. Install PCL5e-c_6_v8.70_v6.70_Setup.exe
    failed because the pc does not detect the presence of Canon IR5570.
    now, I cannot print or scan use to canon IR5570.
    What will I do to solve problem?
    Thank you.
    sigid from Indonesia
  • Vulkor
    • Jun 2009
    • 946
    try disabling Firewalls?
    • darkmaster
      • 50
      How about the M/C change to another IP address?
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        That's your problem right there, the copier can't talk to the PC. I think Vulkor called it, turn off your firewall and try it. You probably need to add an exception for simple file sharing and printing services.
        • bakaoni666
          • Mar 2010
          • 56
          have u solve your problem?
          try the other driver..UFRII
          what's your email?
          • mkharish
            Check It....
            I need Service Support Tool for IR3300 Kindly help me......
            • mkharish
              Kindly Check IP address in PC and IR5570 are same or different, then restart both the machines ..... also check the cable connected is attached correctly ......
