scan to ftp for linux
+ More Options
Posts
  • aleksander
    • 378
    Hi all,
    I'm using bizhub 350 and I want setup scan to FTP and SMB for Linux red hat and ubuntu. Anyone have some solution for FTP and SMB setting both on bizhub 350 and PC using OS linux, please help me.
    Thank you.
  • zed255
    How'd ya manage that?
    • 1024
    You can start with a tutorial like this:
    Ubuntu 10.04 Server: Lucid Print and File Server for Home Network | Badger Bait
    • aleksander
      • 378
      Originally posted by zed255
      thanks zed255, but could you give me the tutorial for using scan to FTP?
      thank you.
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        No offense, but how about you try doing a search in google, I guarantee you will find more tutorials on the subject than you can shake a stick at.
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
        • zed255
          • 1024
          I agree, there are tons of good information out there. Google is your friend. You can make Linux into any kind of server you like. Start with Ubuntu's website and check the support information , then branch out from there. Linux is geared towards the self-reliant, the information and tools are readily available but you need to 'RTFM' before hand 'cause most folks in the community won't totally hold anyone's hand.
          • aleksander
            • 378
            thank you all. But have you ever try using scan to FTP or SMB for Linux users?
            • zed255
              • 1024
              SMB yes, FTP no, but there is no reason why you couldn't use FTP. Users have to be created in Samba (the SMB services package) and shares created with the correct permissions if you want a relatively secure setup or alternatively you can create open shares to make life easy as in the tutorial. Any specific reason you want to use FTP? Most seem to use SMB.
              I'd recommend giving it a try on an old PC before attempting to roll out in a client's environment if you are not familiar with what you are doing. You will learn much just by giving it a try. To make life a little easier you can try a desktop version of Linux and use some graphical tools for configuration to understand whats going on then step into a server version for production. Linux has some advantages and some drawbacks but nothing will replace experience on a system. Go for it even if it means doing it at home first, the knowledge gained will be valuable.
              • aleksander
                • 378
                thanks zed255. Great advice. I agree with you.
                • Laurencia Lies
                  In 1991 while attending the University of Helsinki, Torvalds, curious about the operating systems and frustrated by the licensing of MINIX limiting it to educational use only (which prevented any commercial use) began to work on his own operating system which eventually became the Linux kernel.
                  • RyanPacific
                    Linux Ninja
                    • 97
                    use proftpd or samba respectively. consult the documentation for either to set the server up and consult the documentation for the scanner to send to the server. I have set up tons of low cost ftp scan servers out of old computers laying around for my customers. I recommend using ftp because it is more stable and allows continuation of broken transfers (just don't use external FTP due to plaintext passwords). Use samba to share the ftp server to your users as it is more configurable in respect to file permissions. when set up properly it should need no attention once it is launched.
                    Service Business Equipment
                    New, Used, Refurbished Copy Machines and Printers
                    Copiers in Seattle, Kent, Tacoma and Bellevue
