IRC3220 not found with scangear on XP, W7 firewall OFF
  • x080790
    • May 2025
    On IRC3220 with scangear 2.61 on PC with XP (or W7)
    I am able to ping IRC3220 and I can ping the PC from the IRC3220 in CMD windows.
    Trying to have scangear to see the IRC3220 always fails even with specific IP.
    Can someone point out what I am missing?
  • Herrmann
    • Jan 2006
    • 792
    does the 3220 have a fiery rip attached? if this is the case, you need the "fiery remote scan" tool
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • x080790
      No fiery unit attached
      Thanks for the response.
      This unit does not have a fiery unit.
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        Are you using the "color" scangear or the b/w scangear. I believe it has to have the color to work.
        • mjarbar
          Also create an exception on the Windows DEP for the scangear as this sometimes blocks scangear from picking up the machine!
          • SCREWTAPE
            East Coast Imaging
            • 3396
            What other anti-virus do they have installed.
            Also for the hell of it..
            Why don't you check sevice mode>LVL2>Copier>Option>Body>NW-SCAN
            0: Don't permit
            1: Permit (Invalid when UFR board or open interface board isn't connected.)
            If you see the scan tab chances are its enable.
            Have you tried flashing the machine?
            • copyman20
              • 207
              Not sure if you have tried this.
              Registering ScanGear Tool in [Exceptions] in Windows Firewall
              - For Windows 7:
              1.Click (Start) → [Control Panel] → [System and Security] → [Windows Firewall] → [Advanced Settings].
              2. Select [Inbound Rules] in the [Windows Firewall with Advanced Security] sheet → click [New Rules].
              3. In [New Inbound Rule Wizard], select [Program] → click [Next].
              4. Select [This program path] → click [Browse] → select the file below → click [Next].
              %ProgramFiles%Canon\Color Network ScanGear\SgTool.exe
              5. Select [Allow the connection] → click [Next].
              6. Select only [Private] → click [Next].
              7. Enter a name in [Name] → click [Finish] to close [New Inbound Rule Wizard].
              Registering a UDP port to [Exceptions] in Windows Firewall
              - For Windows 7:
              1. Click (Start) → [Control Panel] → [System and Security] → [Windows Firewall] → [Advanced Settings].
              3. In [New Inbound Rule Wizard], select [Port] → click [Next].
              4. Select [UDP] → enter 56338 in [Specific local port] → click [Next].
              Hope this helps
              Good Luck
