Has anyone set up printing using IPV6?
  • sharpy
    Can anyone help with networking a printer using the new IPV6.
    If you set the printer to DHCP and put that IP into printer port details it cant see the printer.Can you run both V4 and V6 at the same time.
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    You can run both at the same time but the standard tcp/ip port is only for ipv4. As of yet I don't know of any ipv6 printer ports.
    I have a few accounts that had me put in an ipv6 address but still have to use the ipv4 address for all the printing. I'm guessing they used the ipv6 address for the web interface or admin purposes. Even the newest routers/switches are still going to be compatible with ipv4, so just use the ipv4 address for printing.
    • sharpy
      Thanx DLP i will run with that!
      • CanonSco
        Man About Town
        • Jul 2010
        • 368
        snap. not seen ipv6 used solely yet. only in conjunction with 4.
        Yes, I am a nerd.
        Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          ipv4 is all I see.
          • Vulkor
            • Jun 2009
            • 946
            I had one only IPV6. I eventually set it to print via its UNC.. aka \\RNP94234\savin9040
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Ultimately V6 will be king, but that's still a few years off.
              I just saw an article recently about this - the world is almost out of V4 addresses, so it's inevitable.
              I remember some years ago when it looked like V6 would take over soon (maybe in 2001?), but V4 "supernetting" appeared and pushed V6 back a bit.
              • D_L_P
                Self Employed
                • Oct 2009
                • 1196
                I remember people saying that for a long time too, but I've only recently seen IPv6 available in copiers. I guess it's inevitable IPv6 will take over, but I wonder if IPv4 private addresses will stick around??
                It was a University that had an IPv6 address entered as well as the IPv4. Universities always seem to have the newest toys....CAT6, Gigabit ethernets, Win7, IPv6, best internet connection speeds..
                Good to know the UNC will work for IPv6, thanks Vulkor.
