Canon Ir330
  • ebtv258
    Canon Ir330
    Need Help To Change Ip Adress On Canon Imagerunner 330
  • rickr
    setting ip address on ir 330
    the ir 330 uses a fiery print controller. Power off the machine, power it back on, monitor the print i/f until it reads "do you want to go to setup".Click yes quickly and select run setup. manuever to network setup then protocol setup and the tcp/ip. set the ip address and remember to save settings.be patient for the machine to respond
