IC-303 Default Page Order
  • Chromatik
    • Aug 2010
    • 71
    Hi all
    With IC-303 S450 Pro 80 / You can change the default page order on the server?
    Example: 1 to N / N to 1.
    To print the Postscript Test Page, or the calibration page face-up.
    On other servers as IP-921/C500 this is possible.
    Clear from the printer driver that is possible, you can also change the order of default output of the printer, but still can not change the starting order for the system files as postscript test page.
  • albasoul06
    • Chromatik
      • Aug 2010
      • 71
      No problem with the printer driver that's fine,
      the question is: if you can change the default page order from Print Server (Fiery IC-303).
      So you can print the PS Test Page with the face up.
