Fiery Ic-303 / S450 on a Ikon CPP650 / Konica Minolta 6500
  • CreateDC
    • Jun 2025
    i have a IC-303 (S450) Fiery trying to hook up to a Ikon CPP650 / Konica Minolta c6500 ... with all cables unplugged we installed System 2.1 and User 2.1 on the fiery.
    The fiery boots up in Win XP, then loads Command Work Station .... from there it says "Cannot locate print device" ....
    After a few minutes, Windows say its shutting down and the the fiery powers off ...
    I was told that the "Bios" needs to updated / reset?
    any help / suggestions would be appreciated !
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Try with the cables plugged into the copier.
    • CreateDC
      yes, we did that too ... Command Workstation says "cannot locate print device"
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Did you use the IKON or Konica version of the software?
        • CreateDC
          that would make sense, but i am not sure if Ikon has a proprietary ISO install for it ....
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Yep, proprietary it is.
            There should have been restore disks that came with the RIP. As I recall, it's 2 DVDs.
            If not, you'll need to contact your local IKON location.
            • CreateDC
              ok ... that too bad ... i thought the konica would work but .... that makes perfect sense!
              anyones help locating a Ikon CPP650 install dvd would be great....
