Savin 2555 Factory Reset NIC Info.
  • pedoerger
    • Aug 2025
    Hello:
    I have a Savin 2555 with the Print Controller Type 1055/Network Interface Board Type 450-E installed. I am having trouble Printing to the Copier and would like to reset the Print Controller to Factory
  • jonhiker
    • 661
    It is done through SP mode, (service program mode) 5-801-000.
    • pedoerger
      Thanks JonHiker ... How does One get to the SP mode?
      • zed255
        How'd ya manage that?
        • 1024
        It is actually SP5-801-011 to perform an NCS clear (network settings), IIRC. If you are not familiar with Ricoh's SP mode I'm hesitant to suggest you go there, especially among other resets that could make your life more difficult. Having said that, do a few searches and I'm sure you can find it. Good luck and be careful in there, you can make things worse.
        • jonhiker
          • 661
          the B098 does not have an SP5-801-11, it's too old of a copier.
          zed, you are correct, messing around in SP modes can cause problems. i would reccomend you call a technician.
