Colorwise pro tools
  • kjc
    • May 2025
    Colorwise pro tools
    I run command workstation on my laptop and use Colorwise to callibrate Fiery products using a densenomiter.
    all worked well untill last week. (no changes to the laptop) openening Colorwise gives me a window button Java/C++ -3 followed by asecond button Java/C++ -0 then nothing happens no program loads.
    command workstation works fine, i have deinstalled both programs and done a fresh install the same results apply.
    i need to callibrate a customers machine and have to borrow a laptop from an other engineer.
    your help or advise would be appreciated.
    Keith
  • random
    Uninstall CWS and uninstall Java. Both will be in add remove programs. When you install CWS again it will reinstall Java. That may work.
    • Scott_Lewis
      • Mar 2007
      • 519
      I thought I saw a new release of Java last week. If you have the latest, that might have broke your CWS.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        ditto on the java and updadtes.
        Mystic Crystal Revelations
        • OMD-227
          Just had the same problem..... Java C++ errors when starting Colorwise Pro Tools.
          Did not reinstall CWS, just downgraded Java software back to Version 5 from Version 6..... fixed the problem straightaway.
          Dont bother uninstalling CWS, its a Java issue.
          • OMD-227
            Hi again,
            just adding some info to this last reply.
            I didnt actually remove Java 6. I am now running both version 5 & 6 very successfully on my laptop.
            To prove it was a Java issue to myself, I fully removed version 5, then just as before, Colorwise Pro Tools fails to start.
            Again installed version 5 and all works well.
            Laptop is XP Pro, IE6, latest versions possible of CWS & Pro Tools.
