When client PC goes to print using print driver loaded on server 2008 the installed accessories sometimes are forgotten causing print job to fail, anyone seen this ?
Print driver looses installed accessories with Server 2008 and Kyocera 3035
GETTER_DONE
Not sure if you have solved this print problem. But Win 2008 R2 servers require digitally
signed print drivers like the universal drive not the Kx drive we all are used to. Have you swapped a print controller from another unit or load a local driver on an XP or win 7. Sounds like you may have other Kyocera drivers on the server and my need to run kyocera delete program and start over fresh on the server you know IT would just love that. So good luck hope it helps.
