Windows 7 SMB SHARE Problem
  • mams4s
    • Mar 2011
    • 30
    Dear ALL,
    AM Facing problems with Windows 7 smb share on ricoh machines,i put the firewall off then also its not working,is there any setting in windows 7 to be done,please give me solution if anyone have... Thanks in Advance
  • rthonpm
    • Aug 2007
    • 2859
    Make sure you have up to date firmware for the machine: most models need firmware upgrades to work with the newer SMB format used in Windows 7.
    • Herrmann
      • Jan 2006
      • 792
      if all else fails, get "filezilla server" (freeware) and set up FTP scanning, works like a charm
      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
      • aleksander
        • 378
        You must add the guest account when you share the smb folder, change the permission level to Read/Write. Then ho to Advance Sharing and checklist the Full control option.
        Good luck.
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          check for inbound policy on Win 7, there's 3 of them. If it fails, go FTP as mentioned or email. I installed win 7 on my comp just to study the OS, man I'm getting nowhere. I missed XP/Vista
          Idling colour developers are not healthy developers.
          • haggiss
            • 20
            Originally posted by mams4s
            Dear ALL,
            What version Win 7 ? I had similar problems with win 7 home I was told by a propelerhead it wont work so I used FTP
            • mams4s
              • Mar 2011
              • 30
              Am using Win 7 Ultimate,i tried with inboud rules also but still same not working, i dont know what & where is wrong,lets figure it out soon.
              • jonhiker
                • 661
                Windows 7 Scan to Folder SMB.pdf
                here is a document with some things to check on for windows 7 scanning.
