Default printer settings
  • haggiss
    • 20
    has any one had problems with server 2008 and win 7 workstations, where the default settings on the shared print driver under advanced tab are not picked up by the win 7 workstations. I have had to set the default setting on each work station, were in server 2003 it picked up the settings from the server.
    thanks
  • rthonpm
    • Aug 2007
    • 2859
    Have you tried making the settings by going into the printer properties and setting what you want as defaults from the Preferences tab instead of Advanced/Printing Defaults? There's been a few times where setting it this way seems to work a little better...
    • haggiss
      • 20
      Yep tried that but no success
      Cheers Jim
      • Canonguy123
        • Feb 2011
        • 18
        Make sure you check the permissions on the driver on the server.
        • haggiss
          • 20
          Defaults
          Yep we have had some success with changing permissions, but not always, I just cant seem to find a constantly successful way of getting it to work. In 2003 server you set the defaults and 99% of the time it worked, win 7 and server 2008 seem to be a lot more security conscious to the point its a pain
          Cheers Jim
