Ricoh Aficio MP 3500 Shared Folder
  • Gabriel
    • Jun 2006
    • 139
    What's the path or name of the Shared Folder on this Ricoh MFP.
    (The folder where are stored the documents scanned into the Copier itself)
    Any help is welcome
    Regards
    Gabriel
  • rthonpm
    • Aug 2007
    • 2849
    I'm guessing you mean the Document Server? While the copier can use Samba to access external share folders, the Document Server is partitioned on its own section of the drive and isn't accessible from the external network except through the web interface of the machine. Even from there, the files are pretty much useless unless you have a file format converter which will allow you to download the files as PDFs since they are stored in a proprietary format.
    • Gabriel
      • Jun 2006
      • 139
      rthonpm
      Thanks for the fast response and sorry I just back from vacations
      You got it,
      Do you know what file format converted can be used or what format are the scanned document stored?
      Regards
      Gabriel
      • rthonpm
        • Aug 2007
        • 2849
        The scanned documents are natively stored in a proprietary format. The file format converter is usually model specific, though I could be wrong on that. I don't have my manuals handy this moment.
