Copystar 2050 dropping offline.
  • alpha-omega tech
    • 80
    I have a Copystar 2050 will print one page then drop off line everytime. I bypass the switch and cancelled all the documents in the queue. I can turn the copier off and on and it will print one print and drop off line. Any Ideas?
  • marc
    • Feb 2010
    • 56
    Re: Copystar 2050 dropping offline.
    maybe it's conflict ip address, try with different ip address
    • Jules Winfield
      • Jul 2009
      • 821
      Another way to test for an IP conflict is to unplug the network cable from the printer and then ping the IP address the printer was using from a PC on the network. If you get a response then there is another device on the network using the same IP address.
      But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
      • alpha-omega tech
        • 80
        Bad switch. Replaced the switch and it worked. Odd thing though, when I plugged it into the wall, bypassing the switch, it would still drop out and go off line. When I replaced the switch it never went off line.
        • Jules Winfield
          • Jul 2009
          • 821
          Was the switch still plugged into the network? If it was then perhaps the information for the printer was still in the switch's routing table.
          • alpha-omega tech
            • 80
            No, the switch was completely removed.
