Scan Router Pro Question
+ More Options
Posts
  • copycowboy
    • Aug 2011
    • 18
    Does anyone know if scan router Pro is still available for purchase from Ricoh? also if it is has anyone here configured incoming fax routing using Scan Router Pro to go to different emails.I know is and old program but im being asked to configure it..if anyone has any quick instructions on how to do this it would be greatly appreciated.
    The CopyCowboy
  • ddude
    General Troublemaker
    • 473
    Re: Scan Router Pro Question
    Yes, I think that it is still available for purchase, but I am not familiar enough with fax routing on Ricoh products to give any good help here.
    2000 mockingbirds = 2 kilomockingbirds
    • copyman20
      • 207
      I don't think they sell Scan Router Pro anymore. They don't even sell the later version Scan Router EX Pro.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        It is no longer sold, and hasn't been for a while.
        It's replacement is GlobalScan.
        Unfortunately, SR Pro was a champ at fax routing; even GlobalScan is somewhat limited on what it can do with fax routing.
        What model machine(s) do you have?
        Is this something you can do with... dare I say it...Special Senders?
        • copycowboy
          • Aug 2011
          • 18
          The copier is a Savin 2828. I tried to configure incoming fax routing to diffrent emails using subcodes but wasnt to succesful. According to the manual it supposed to work. But it clearly does not. I am not a big fan of Global Scan NX. I just had way too many issues with the earlier version of Global Scan and the earlier versions of java. I'm sure a lot of the bugs have been fixed but I am just assuming that..So because the company I work for doesnt have Ricoh support anymore I will not be making a recommendation of Global Nx. Thanks for letting me know about the scan router question.
