Xerox DC-260 Fiery controller unable to ping
  • jpat
    • Sep 2011
    • 10
    My xerox Docucolor 260 bustled controller doesn't connected with router and I am unable to ping it, although the network card as well as router shows the green light.
    Try to assigned the static IP address in controller panel still no luck.
    Any quick help will be greatly appreciated.
  • bojans
    • 1313
    Re: Xerox DC-260 Fiery controller unable to ping
    Did you put good IP address? It must be in the same range. For example If your printer has address 10.0.0.1 your comp must have 10.0.0.X, only last number is changing. It also must have same subnet mask.
    Just a thought.
    • jpat
      • Sep 2011
      • 10
      IP address I have assigned was 192.168.1.9 and gateway was 192.168.1.1
      still no sign of connectivity!
      Unable to understand this problem, tried restart couple times.... No luck
      • bojans
        • 1313
        What's the printer IP adress?
        • jpat
          • Sep 2011
          • 10
          The controllers IP address is 192.168.1.9
          Can we add the additional network port card to controlle, linux lilo compatible?
          • bojans
            • 1313
            It's simple.
            Print configuration.
            YOu'll find this:
            IP Address: 192.168.1.9
            Subnet Mask: 255.255.255.0 (for example) could be other numbers
            On your computer set
            IP address 192.168.1.10
            Subnet Mask: 255.255.255.0 (if it's not this type numbers from configuration)
            Ping 192.168.1.9
            • jpat
              • Sep 2011
              • 10
              No luck doing this as well.
              somehow the controller is not showing in activity with router.
              I have tried dirctly hooking to my desktop but same problem... no pinging.
              • rthonpm
                • Aug 2007
                • 2859
                Kind of an obvious question, but are you using a good network cable?
                • jpat
                  • Sep 2011
                  • 10
                  I have tried another cable as well, looks like port on mob is a issue.
                  • jpat
                    • Sep 2011
                    • 10
                    Any further help or expert comments from anybody?
                    Appreciate for your time and suggestions.
                    • ddude
                      General Troublemaker
                      • 473
                      Use the computer and a crossover cable direct to the printer, with IP addresses within range-
                      (printer)
                      ping from computer. This will tell you if the printer nic is working.
                      2000 mockingbirds = 2 kilomockingbirds
                      • jpat
                        • Sep 2011
                        • 10
                        I tried exactly how you explained.
                        Still no luck....
                        I suspect the network port on motherboard is dead and the IP addresses stuck to that somehow, the new network cards has been picked up by system and shows the green light also but not picking up the new IP addres assigned through the copier control panel.
                        Please see if anyone has any idea to make that NIC work with the new IP address.
                        • xcopytech
                          • Aug 2006
                          • 1794
                          Did you tried to reload system software to fiery?
                          • jpat
                            • Sep 2011
                            • 10
                            I have v.2 disc part 2 only. misplaced the first one.
                            Is there any reset option for firey software?
                            Tried factory reset with no luck.
                            • ddude
                              • 473
                              So you program the new IP address through the control panel, yet when you print out a config page the new address is not shown?
                              I know from experience that when you are programming a fiery, you must maneuver through a complicated tree of commands in the proper sequence before any selections are preserved-and you must have a valid password in order to change any settings- you may need to look at your fiery command sequence.
                              Try changing one simple item in the Fiery console, like the printer name, or the DNS, then exit, and print a config page to see if your change was accepted- this will show you that you do have the ability to make changes-
                              I am sorry if this sounds basic, but your symptoms point to a 'rights issue' or an acceptance problem with the Fiery. Let us know so we can help you-
