Konica Minolta Magicolor 7450
  • alejandro
    • Mar 2008
    • 33
    Hello all,
    When I print from my mac (Snow Leopard) to my Konica Minolta Magicolor 7450 it takes around 20ms to print 10 posters 11x17 from preview or any other software. It seems that it process each print and takes around 2 mins for each.
    The mac and printer is connected thru a ethernet cable. No network, just straight cable.
    Can anybody help? Is there a better way to connect the printer so it rips the jobs faster?
    thanks
  • RRodgers
    • Jun 2009
    • 1947
    Re: Konica Minolta Magicolor 7450
    Originally posted by alejandro
    Hello all,
    thanks
    make sure collate is turned off.
    • alejandro
      • Mar 2008
      • 33
      Thanks RRogers, Ill try that, but I havent seen that option on the Magicolor 7450. And if is there, does that really males the ripping that much slow?
      thanks
      • ddude
        General Troublemaker
        • 473
        The collate would be a check box in the print driver-when collating, it may be re-sending the print job multiple times. You may also want to check (uncheck?) any spool settings, as this will slow down a print job as well.
        2000 mockingbirds = 2 kilomockingbirds
        • alejandro
          • Mar 2008
          • 33
          I did unchecked the collate option and it changed big time!!!! thanks a lot. ill try couple more jobs to check the time.
          • RRodgers
            • Jun 2009
            • 1947
            This is why I get paid the big bux!!! hahahah (errr or not)
            Glad you got it sorted. On an XP box with a Fiery that collate box causes ALL KINDS of weird probs. Always have it off.
            • alejandro
              • Mar 2008
              • 33
              Thanks a lot for your help. Its printing great now. god bless.
