Ricoh 1045 network settings no where to be found.
  • Rambo
    • Sep 2011
    • 15
    Hi, im trying to setup print/scan on my ricoh 1045 but for the life of me i cannot find the network settings on the control panel for setting it up on the network lol.
    right now i plugged a cross-over from laptop, to copier and the lights are on and its live.
    Now where do i find the network settings? thanks
  • copres
    • May 2011
    • 41
    Re: Ricoh 1045 network settings no where to be found.
    Use "User Tools/Counter" button on the op panel to get in to "system settings" - network setting should be there. Once you change IP address to your network pool you can use web setup to finish it.
    • Rambo
      • Sep 2011
      • 15
      theres nothing. I go user/tools>system settings>interface and i only see 2 parallel port settings.
      Is my copier missing something? firmware? or network board?
      this is frustrating as hell lol.
      • copres
        • May 2011
        • 41
        Lets go back to basics - does your copier have printer and/or scanner buttons on op panel? If they are present does the screen changes when you press any of them? IF copier has no other buttons on the left except "copier" and "document server" then your mission is over. For copier to be able to print and scan it has to have some hardware present - nic card, extra memory and print/scan boot rom.
        • AirborneGecko
          If it does have the print scan option...my memory machine seems to remember having to enable the NIC through SP modes on some older Ricohs. Sorry worked on a C900 today my brain power is almost used up.
