Smb scan to folder on win xp sp3
  • mams4s
    • Mar 2011
    • 30
    Dear Guys,
    I am facing problem on Ricoh MFP in SMB Scan to Folder with windows xp sp3 with many security updates installed,i dont know which one is stopping me.when i try to configure the scan to folder am getting this message Cannot fine Specified Path but the path am giving in ok,i tried with ip and Hostname.both are not working,your help will be appreciated..
  • TheOwl
    • Nov 2008
    • 1732
    Re: Smb scan to folder on win xp sp3
    Can you access the UNC path (\\pcname\sharename) from another computer on the network?
    Can you write files to that path using the credentials that the machine uses?
    Are you using Simple File Sharing or the advanced method?
    • mams4s
      • Mar 2011
      • 30
      I cannot access in anyway, am trying advanced method only.....
      • cadkins
        • 34
        What model machine is this??
        Can you access it the way TheOwll suggested originally?
        Go to another computer and do :
        1. Click "Start"
        2. Click "Run"
        3. In the dialog box that pops up, type in the same path you are using in the copier. What happens?
        You can also, take out all user names and password for this entry and type in just the computer name (\\computername) and then click the browse network button to see what happens. It should say it can't log in with the user name and password. Make sure the "Default Username and Password" has the right credentials.
        Is the folder being shared?
        Does the computer have McAfee 360 installed? I have had some issues with this getting it to be able to scan.
        • mams4s
          • Mar 2011
          • 30
          1. Click "Start"
          2. Click "Run"
          username and password are all correct but still same.yes MCAfee is installed with xp sp3 and many security updates also...
          • rthonpm
            • Aug 2007
            • 2847
            The McAfee is probably causing your issue: it doesn't see the copier as a 'trusted' computer. Add it to the trusted list in the firewall settings and you should be alright. Have to love poorly configured security software...
            • mmurray
              Check to see if an update installed windows live ID. If it did, remove it and try scanning again. It can always be added again later. After it is removed, browse the path from the device. If it can now login using proper credentials, you should be good to scan.
              • AirborneGecko
                Might want to consider firmware. Some of the Microsoft patches are screwing with SMB scanning.
                • RRodgers
                  • Jun 2009
                  • 1947
                  Yep, its probably that. Go in and make an exception for the copiers IP.
                  • yousaf
                    • Jun 2010
                    • 43
                    Re: Smb scan to folder need to setup
                    hi
                    any body can write to me all steps to configur the smb scan to folder. the copier is MPC 2050 in this copier i can't see the place for ip of the computer. plz write me alll steps thanks its realy help me out.
                    thankssssssssssssssssssssssss
                    bye
                    knight
