Coinfiguration question
+ More Options
Posts
  • JVC
    • Jun 2011
    • 151
    Hello
    I have an es2500c that I am having trouble printing with.
    I have loaded the driver and can print but when I go to the printer properties it shows all the trays have letter in them. When I go to the configuration tab all the options are grayed out. Any thoughts?
    Joe
  • rthonpm
    • Aug 2007
    • 2847
    Re: Coinfiguration question
    Is it a shared driver from a server? If so, you may not have rights to change the configuration.
    • JVC
      • Jun 2011
      • 151
      I loaded the driver on the laptop with the driver I downloaded from toshiba fyi.
      • rthonpm
        • Aug 2007
        • 2847
        Check the permissions on the driver: your account for some reason may not have rights to change the accessories or options. See if you can add your account to the Manage Printers group with the rights to Modify.
        • TheOwl
          • Nov 2008
          • 1732
          What port are you using to print to the device with?Have you tried checking the properties of the driver when you are logged in as the administrator?What about from another computer?Is it shared from a server?Is it shared directly from the copier itself?Any other printers exhibiting the same issue?
