Windows 2008 R2 64 bit Drivers Issue from Client Side
  • mams4s
    • Mar 2011
    • 30
    Dear All,
    I have a Ricoh Machine MPC 3500, i installed the PCL6 driver on Server Windows 2008 R2 64 bit OS.Printing fine.this Printer is Shared over network.when i connect this printer from the client Pc is giving some Error not proper drivers installed.even if i try to browse the compatible drivers from client pc it is not working..
    what can be the reason is there any setting on server side...
  • Mooseface2r
    • Jan 2011
    • 114
    Re: Windows 2008 R2 64 bit Drivers Issue from Client Side
    is the client 64bit? if not under sharing on the printer properties on the server install additional 32bit drivers.
    • DrJive
      IT Team ******
      • Jul 2011
      • 15
      Yeah sounds like you need the 32 bit driver installed on the server. Just add the x32 driver using Print Management or server properties no need to configure it Windows will handle the association between 64/32
      • TheOwl
        • Nov 2008
        • 1732
        1. Printer Properties
        2. Sharing
        3. Additional Drivers
        4. Tick x86
        5. Ok
        6. Point to the 32Bit drivers
        7. Ok
        This will install the 32Bit drivers for your clients. You must make sure that you use the same version as the 64Bit drivers that are installed or you will get more errors when trying to complete the above.
        • mams4s
          • Mar 2011
          • 30
          thank u guys for reply..i will try this,hope this will fix my issue
