SharpDesk Problem
+ More Options
Posts
  • m.verucchi
    mtech
    • 18
    SharpDesk Problem
    I have multiple customers that call in saying they cant scan. The copier displays selected server not found. I go to sharpdesk product configuration and auto detect for scanners. After doin this, everything works fine. Is there any solution to keep this from happening?
  • DavePo
    • Jul 2008
    • 305
    Re: SharpDesk Problem
    What version of Sharpdesk are they using? Old versions like 2.7, 3.0 didnt work with networks running DHCP addressing well. If using vers. 3.2 or 3.3 are the profiles set to update automaticlly? Are they running DHCP? Is network scanner tools looking at the DNS name or IP adress. Usually using DNS is preferable. How often do they restart their PC's? The autoupdate feature on NST updates after bootup.
    • colgrimes
      • May 2012
      • 64
      M,
      my suggestion is to enter the DNS settings in the network config of the Sharp MFP web page, then have the scanner send to the computer's names rather than their IP addresses, which are constantly changing, obviously.
      2nd suggestion would be to set the computers to static ip addresses rather than DHCP, but this would require more work, and again, the DNS settings from the router.
      -colgrimes
      Skelton Business Equipment Houston Copiers
      CopierCollin.com
      Hybrid Honest Sales/IT
