Scan to SMB Win 7 home
  • MFPTech
    • 486
    Has anyone been able to set up scan to smb in Win 7 Home please?
    Selected the right settings for the shared folder, Advanced Sharing, Windows Firewall, opened TCP port 139, you name it. The only thing I haven't done is a data capture because I haven't found a new hub yet.
    Thanks in advance!
  • JR2ALTA
    • Feb 2010
    • 2030
    Re: Scan to SMB Win 7 home
    Try IP instead of hostname?
    • Eric1968
      • 2458
      If you're using a password on your PC make sure that password protected sharing is enabled.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        Useing IP should eliminate any host name DNS issues. The folder that is shared also needs to have the read write permissions set for the user name. The user must also have a valid password if password protected shareing is enabled, or you could turn off password protected shareing. see the attached PDF's
        Windows 7 scan to folder.pdfAdvanced Firewall settings for SMB scanning with Windows7.pdfWindows 7 Scan to Folder SMB.pdf
        Mystic Crystal Revelations
        • MFPTech
          • 486
          Thanks for the pdfs, will try to set the scope for remote ip to any ip and will let you know.
          Forgot to mention that I am trying to set up scan to folder on my Laptop that runs Win 7 Home using a crossover cable. I also run a Virtual PC using XP and had no problem scaning to SMB on XP.
          • Eric1968
            • 2458
            Don't know what machine you're using to scan, but some machines can't scan to SMB to a Windows 7 system. I know that some of the older Ricoh machines must have a firmware upgrade before they can scan to Windows 7.
            • MFPTech
              • 486
              Canon Image Runner 1730 IF out of the box.
              • xeroid
                Document Technologies Pro
                • 148
                run ipconfig/all from a command prompt and check out the user name at the prompt (C:\users\xxxxx\) Be sure you are using the user name (xxxxx) identified at the prompt in your scan address config.
                Hope this helps.
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  The user name should be identical to win 7 security credential.
                  Ie.. administrator (hp-pc/admin)
                  You would put whatever its in the bracket as user name.
                  Another example .... Admin(tonermonkeh@copytechnet.local)
                  Idling colour developers are not healthy developers.
                  • Rasmussener
                    I do not know which machine you use to analyze, but some machines can not scan to SMB to a Windows 7. I know some older machines have a Ricoh updates firmwarebefore you can scan for Windows 7.
                    • mojorolla
                      The Wolf
                      • 2589
                      Try uninstalling Windows Live Essentials.
                      • mjarbar
                        I have noticed that you are using Win 7 Home edition but as I understand it scanning to SMB requires a domain type network setting which the 'Home' edition does not support.
                        You have said that the virtual XP does work so can I ask what version of XP you are using? If it is professional this was designed for networks as you know and would work.
                        Just my 2c's
                        • rthonpm
                          • Aug 2007
                          • 2849
                          The Home editions of Windows 7 cannot join a domain, but they can be part of a workgroup. Samba and CIFS both support workgroups and domain connections so that's not the issue.
                          Make sure the network setting for the computer is set with the network as either a Home or Work network. You may also want to change the workgroup name to something other than 'workgroup' in order to make sure that the two are properly communicating.
                          Does the MFP allow you to do a network browse?
                          • morpk
                            • Oct 2010
                            • 97
                            This would normaly be an authenication issues, i work Konica minolta Machines and you sometimes need to set the machine to NTLM V2 authenication in SMB
                            just as a check
                            in the scan button
                            1. enter IP/ hostname
                            2. enter scan UNC Path e.g data\scans
                            3. enter username
                            4. enter password
                            5. check share permissions on the scan folder e.g give the user you are authenicating with full permissions
                            6. maybe (but not normally) give full permissions under the security tab
                            • tjvincent
                              • 280
                              Does anyone know how to set up a 2nd static address on the workstation if you have to use the IP address when the host name won't work ? We get it to scan by using the workstations IP, problem is since the workstation uses DHCP it eventually changes and then you loose the ability to scan to that workstation.
