Hi everyone,
I recently acquired a Konica c252p printer (no usual display or finisher/scanner) with an extremely low print count.
Being a "professional," I need to be able to calibrate the printer like one would with any real copier/printer. To allow technicians to do this Konica created "Jig Software" or an "External Panel Control" where one must connect a computer via serial port, run the software and get the typical konica control panel on their computer screen, etc.
Anyways, I have the software, the field service manual and the troubleshooting guide, a serial cable, and computers, but cannot get the blasted thing to cooperate.
Here is my predicament:
I am able to connect via serial port (it will give an error it does not connect or you select the wrong com port); however, the "External Control Panel" never presents itself in the program--it just stays on the intro screen (see c252p manual page 89-95). And yes, I have the 252 set in "trouble reset" mode, and have tried various sequences.
(The program displays question marks on the bottom left--if that means anything to anyone....)
I can send anyone who is interested the debug and message logs in a .zip file (as well as the other files it created when it was closed).
The most interesting is the following in the debug log:
The manual is extremely and frustratingly vague:
I have tried multiple computers (all running winXP), and even tried all the different address for the serial port in BIOS (just to be thorough).
Any ideas??
Thanks in advance!
Nick
"FILC_BaseDir::makeContents = ERROR
Invalid MagicNumber: 14
Invalid MagicNumber: 13
Invalid MagicNumber: 12
Invalid MagicNumber: 0"
(I guess I don't have the magic number.)Invalid MagicNumber: 14
"9.1 Calling the Service Mode to Screen6. Start the Jig software and check to make sure that the Start screen will change to the
Panel screen.
7. Click the Utility key.
8. Click Details key.
9. Press the following keys in this order:
Stop → 0 → 0 → Stop → 0 → 1
10. Service mode will be displayed."
Panel screen.
Any ideas??
Thanks in advance!
Nick
