Pushing out a printer via a login script
  • JSC
    Gimp
    • Dec 2006
    • 618
    Does anyone have some helpful info on how to push out a printer via a login script, i have to install a kyocera ta next week and I have just found out there are 60 users and their one and only IT guy is off on long term sick. I am off to the font of all knowledge 'google' after I have posted this, but if anyone can give me some pointers that would be great.
    The gene pool could use a little chlorine.
  • TheOwl
    • Nov 2008
    • 1732
    Re: Pushing out a printer via a login script
    Does this customer use a server and if so, what operating system is it running?
    With Windows Server 2003, you could download and install "con2prt" which you can call from within a login script.
    If you are running Windows Server 2008, then you can push the driver out by Group Policy. Once you have the Group Policy setup, then you can test that Group Policy by jumping on a users computer and typing in "gpupdate /force" with out the quotation marks. If it works, then just get your users to restart their computers.
    • JSC
      Gimp
      • Dec 2006
      • 618
      Thanks for the info TheOwl, as it turned out they had a IT guy there when I turned up.
      they did indeed have server 2008 and we pushed out the driver via Group Policy. But I will definately have a 'play' with the con2prt.
      Thanks for the help and Info.
      • morpk
        • Oct 2010
        • 97
        find the best way is a simple VB Script or GPO is the way to go. but you can see if the IT person is already running a script:
        \\servername\netlogon
        there might be a .bat file or a .VBS running you can always piggyback off an already running script.
