Konica Minolta C351 email using SSL/TLS
  • mattwill1107
    • Aug 2008
    • 26
    I have a Konica Minolta C351 that in the web interface for Email transmission setup, does not show a check box for using SSL/TLS for outgoing emails. However, the network scanning manual shows a check box to select that. Does anyone know if the addition of SSL/TLS for outgoing email was part of a phase or firmware upgrade? I can't find anywhere with Minolta that speaks of the SSL/TLS for email being added through a firmware upgrade. Thanks.
  • TheOwl
    • Nov 2008
    • 1733
    Re: Konica Minolta C351 email using SSL/TLS
    If the machine isn't running the latest firmware, then I would suggest that you update the device anyway.
    As you might know, the setting should be under:
    Web Interface - Admin - Network - Email Setting - Email TX (SMTP) - Use TLS/SSL
    May I ask what sort of server you are using? GMail, Live, Exchange...?
    If it is Exchange, then let me know as I have a way around the TLS which is builtin to the standard Receive Connector or Exchange 2007 and up.
    • mattwill1107
      • Aug 2008
      • 26
      Thanks for the reply. They are using gmail servers (used by their ISP). I saw the bulletin relating to the exchange issue. I am going to be performing a firmware upgrade, as I did discover they have pretty old firmware. I'm optimistic Thanks again.
