Ricoh Aficio 3500 - Scan Folder & Connectivity Issues
+ More Options
Posts
  • lola8888
    #16
    Re: Ricoh Aficio 3500 - Scan Folder & Connectivity Issues
    Did you try logging off of the computer. Then log back on the computer. Then try it again.
    • redneckstylin
      • Sep 2011
      • 173
      #17
      how i get past all that crap is create a new local user name it ricoh and run high cypher stength password...that way you have all admin rights and just give ricoh user all permissions create folder on root of c drive orrrrr you could try direct i.p. aka \\192.168.1.1\scans
      • akewldewd
        • Dec 2012
        • 83
        #18
        Originally posted by Chameleon
        Sounds like very much like a symptom of a user not being "Modify" or "Write" access to the Shared Folder. Right click on the shared folder and click Security" tab and check that the user isn't just given read permissions. Win 7 doesn't give users rights by default and they need added under the security tab.
        Thanks for the suggestion, all are appreciated. I have done this. I am usually able to connect now but ocassionally still find one that just won't. I think because of computer name changes that were made. I haven't tried the create a new account solution yet because I am thinking the old user may not be able to find certain folders and data if I do without having to sign back on to the old account. I wonder if making the new account an administrator or sharing all folders on their account may solve that issue. I guess I need to experiment a little.
