You may want to try EB-1357 drivers (the Fiery for the 907 series). It should be similar enough to get output.
The issue I would see with it, though would be the finishing options, and perhaps even some of the paper trays being different.
Worth a shot, I guess.
Did the customer even bother to contact you before hand to see if Windows 7 would create any issues for this machine? (On second thought, never mind... forget I even asked...).
Thanks I will try that driver if all else fails I will set up a kvm switch with a shared drive to a barebones xp machine
And the answer it you last question is........ well you probably already know
