Ricoh MP1600L with print server
  • minolta35
    Trusted tech
    • Apr 2005
    • 87
    Is it possible with any print server MP1600L (like Edimax or Ladox etc.) works together like a network printer?I tried to with Edimax 1206U model print server but i didn't successfull.Do you offer any idea?
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    • minolta35
      Trusted tech
      • Apr 2005
      • 87
      Originally posted by iMind
      for this machine you´ll have to use the DDST Printer Driver,
      i think that this machine 1600 L has only a USB connector, is that right? only the LN has a network card, with pcl drivers you can ping the card but it will not work. only DDST Printer Driver will work but you must change the standard printer port from 9100 to 10001 just like you had to on the 1805. try it out
      Yes, I know it.
      But there is cost differance between 1600L and 1600LN.I want to know 1600L is connected any external print server works like 1600LN?
      • iMind
        • Mar 2008
        • 1116
        Sorry, no help.
        never tried it out, only instaled one print server an it was on a 10505 with and internal fiery EB-105 needed to use a print server to print on a certain software, I can remember that the Admin used a HP native driver.
        Let me know if you over come the problem.
        Good Luck.
