Windows SBS2011 not able to share C353 series drivers 64bit
  • habik
    • 2013
    SBS2011.jpgAny way around this matter? Tried PCL, PS, XPS ,UPD drivers..none of them are able to be shared. Get error message 0x0000006d9SBS2011.jpg
    Firmwares HERE
  • bperdue
    • Jul 2012
    • 8
    Re: Windows SBS2011 not able to share C353 series drivers 64bit
    The link below helps if you have trouble connecting to a shared printer. I have had issues connecting to a shared printer, but never had an issue sharing the printer. Hope this helps.
    Local Printing
    • morpk
      • Oct 2010
      • 97
      Originally posted by habik
      [ATTACH=CONFIG]17091[/ATTACH]Any way around this matter? Tried PCL, PS, XPS ,UPD drivers..none of them are able to be shared. Get error message 0x0000006d9[ATTACH=CONFIG]17091[/ATTACH]
      found this dose this apply to you possible firewall issues
      Error 0x0000006d9 When Sharing a Printer | Toronto Technical Support
      hope it helps
      • habik
        • 2013
        Originally posted by morpk
        found this dose this apply to you possible firewall issues Error 0x0000006d9 When Sharing a Printer | Toronto Technical Supporthope it helps
        Thanks, will give it a try tomorrow
        Firmwares HERE
