Scan to Gmail
  • duroo72
    • Nov 2009
    • 30
    Scan to Gmail
    Hi Chaps,
    Have experienced a few failures of scan to gmail recently.
    My settings are: mail server - smtp.gmail.com (have tried ip address as well)
    ports 465/587
    ssl "ON"
    dns set to the same as the local pc's along with a secondary set as googles own
    the default gateway is correctly set on the copier
    trusted and working gmail account as authentication ie scanner@gmail & password
    As many of you are probably aware you can test connectivity of the smtp settings from the web page on the latest sharps (ok not a full test but it proves some connectivity is occuring) which on my most recent install proved positive and the results saved but when an email is actually sent from the device the ce-00 error code is displayed failure to connect! Ive tried the customers domain email accounts and my own hotmail address as destinations but still no joy.
    This also occured on a konica minolta C20 recently as well , to all intense purposes the settings are correct and have been used in 100's of installs before excluding email accounts.
    I thought it maybe the switch blocking certain ports but the latest customer just has a basic netgear router in place so nothing special going - do you guys have any ideas?
    Cheers in advance.
    A+,Network+,Pdi+,Cdia+,MCSE,Konica Minolta Outward Associate
  • mojorolla
    The Wolf
    • 2583
    Re: Scan to Gmail
    Gmail has had some issues the past few weeks. You may also want to check the spam box of that gmail account. If it fills up, it can cause sporadic connectivity issues.
    • duroo72
      • Nov 2009
      • 30
      Re: Scan to Gmail
      Thanks mojorolla it is a new account so spam empty , interesting re gmail having probs - what issues have been occuring?
      • morpk
        • Oct 2010
        • 97
        Re: Scan to Gmail
        Had one of my techs have this issue yesterday the way around it was,
        1. set the SMTP server as the isp e.g a common aussie ISP is Bigpond so it's smtp server is mail.bigpond.com
        2.most isp dont need authentication so to run through unless the error says login error
        so what is going to happen is copier - router- ISP-gmail- users email
        it might be a bit rough but it dose work.
        • duroo72
          • Nov 2009
          • 30
          Re: Scan to Gmail
          HI morpk can you detail >> "so what is going to happen is copier - router- ISP-gmail- users email" this more please?
          Thanks in advance
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            Re: Scan to Gmail
            To me it sounds like a classic DNS resolution problem, try using Googles primary and secondary public DNS (8.8.8.8 and 8.8.4.4, respectively) over customers own DNS settings.
            Make sure the customer isn't blocking outgoing connections, some people think they are more secure this way, but it just causes more problems for everyone.
            • morpk
              • Oct 2010
              • 97
              Re: Scan to Gmail
              Thanks in advance
              copier (sends email) > internet Router (sends to ISP's SMTP) > ISP's SMTP Sends to gmails SMTP > Gmail Sends to user.
              so let look at another example my work email runs off exchange if i send an email to user@gmail.com my email client send the mail to my exchange box and my exchange sends to Gmails smtp server and gmail delivers the mail what i'm suggesting in the scanning is the same thing but it is going to be routed through the customers ISP SMTP Server
              so if the customer ISP is Bigpond my settings would be
              SMTP: mail.bigpond.com over port 25
              no authentication
              send address scanner@whateverdomain.com
              i hope i made sense
              • ddude
                General Troublemaker
                • 473
                Re: Scan to Gmail
                Yep- best rule is to stay away from external outside email servers-the reliability just isn't there.
                2000 mockingbirds = 2 kilomockingbirds
                • duroo72
                  • Nov 2009
                  • 30
                  Re: Scan to Gmail
                  Isp mail account does work cheers!
                  • morpk
                    • Oct 2010
                    • 97
                    Re: Scan to Gmail
                    Glad to hear you got it working
                    • blancomputer
                      Re: Scan to Gmail
                      no authentication
                      i hope i made sense
                      If the customer has 2 step login for gmail Ie. login with user name and password then it sends an sms to a moblie phone with a second code to logon to mail. this stop anything going to gmail account. you need removed 2 step system so send to Gmail.
                      Note: about bigpond the have started placing users on to hotmail live servers.
                      • morpk
                        • Oct 2010
                        • 97
                        Re: Scan to Gmail
                        this is only a work around if the gmail servers just don't want to play ball,
                        as copier techs we need to get the email to go from a to b if the customer has multiple logon requirements then good for them, but if the copier can send to a mail server with no error's then it has done it's job. and the way i have told to set this up doesn't require authentication there for the password and SMS code become irrelevant.
