Scan to e-mail SSL MPC2550
  • lovelash
    #16
    Re: Scan to e-mail SSL MPC2550
    Originally posted by Ralph S
    Hello "anothertech", I beleive that this makes the MFP's web page secure so that the http://<ip_address_of_printer> no longer work, and you need to use https:// to get to the machine. I do not beleive that this will provide the SSL/TLS funtion for authentication to the email server if the OPTION is not available on the usertools touch screen for file transfer, SMTP server.
    9Apps APK Cartoon HD | Download Cartoon HD APK APP for Android Free! [2019] VidMate APK
    I am on the phone with Ricoh support right now asking about scanning to Excahnge 365 which requires SSL/TLS on port 587 encryption. My current issue is on a MPc3502 which does have this feature, and the PORT shows that it is 587, and a connection test works, but email sending does not.
    Ricoh provides solutions, but so far only as an added service to the base machine, thru eCopy, Globalscan, and other external solutions.
    Damm the exact same problem is with me but I am unable to find a solution for this !!
    • davel
      • Oct 2011
      • 1109
      #17
      Thread is 6 years old, dead and buried as should be that MPC 2550, too old Also Queensland is in Australia not India.
      • jtorres
        #18
        QUIT TRYING TO MAKE GMAIL WORK.
        USE SMTP2GO.
        I spend a latter part of the day trying to get certificates and proper settings for my Ricoh MP C2500
        Setup - SMTP2GO
        Made an account and it worked the first time!
          • 37653
          #19
          I have had security problems with smtp2go. I have never had trouble setting up scan to gmail. Just follow the Google Support instructions. Send email from a printer, scanner, or app - G Suite Admin Help
          If you need to install a certificate follow these instructions from Ricoh.How do I setup SMTP over SSL on a Ricoh Family group device.pdf
          Current [Google Internet Authority] in Firefox is found under GlobalSign
